Originally posted by russian
(panic mode) axles, transmission and differential gears
Take the clips off and slide the axles in. If they go in there is no problem with the tranny but a problem with the clip and/or installation. If the axle doesn't go in still, there is a problem with the tranny.The Festiva Store
He already said he tried WITHOUT the clips....Originally posted by nonamekid View PostTake the clips off and slide the axles in. If they go in there is no problem with the tranny but a problem with the clip and/or installation. If the axle doesn't go in still, there is a problem with the tranny.Last edited by nitrofarm; 01-20-2012, 08:42 AM.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
You are looking for SPLINES! Gears & splines. Stick your face in there. Look in the holes.And you should be able to see clean through the tranny.Originally posted by russian View PostDoes anyone have a sketch of F gearbox inside? Would be helpful to know what I am fishing for
(And should see two sets of splined side gears for both axles. It doesnt matter if its a E,F or G series.They are all going to have similar side gears with thrust washers.Last edited by nitrofarm; 01-20-2012, 08:45 AM.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
Lol, misseOriginally posted by nitrofarm View PostHe already said he tried WITHOUT the clips....
d that with all the confusing posts of people who don't have a clue what's going on. I have never had the gears move on me even with trannies that have had the axles removed and been stored for awhile and moved around alot. I have seen damaged splines on axles though, people getting too aggressive with a hammer and trying to force things.The Festiva Store
If the clips buggered up the splines they are easy to file. If you have
the F transmission the gears should not slip like they can on the festy
transmission. If you have messed up splines the clips are too. May
need new ones. The gears are harder spline material and will not
be messed up as easy as the shaft can get messed up. Even a dremel
tool can fix bad spline spots.Reflex paint by Langeman...Lifted...Tow Rig
??? I have thrown them from car to car dropped them with no problems .ButOriginally posted by nonamekid View PostLol, misse
I have had the gears drop before . Sucks breaking the case to correct the problem and do it again Haha .. but I don't have a clue !New build on the way .
So what happend to "stock manual trans", now its an f-series? If your trying to use stock e-series axles in the f-series that's the problem.Originally posted by russian View PostI was struggling to lock axles back into my stock manual transmission after an engine swap and at some point after multiple ins/outs/light hammering they have stopped even going inside as deep as they used to go in! It was 1/4" out while I was struggling and now it is 3/4" out! And as soon as I have realized things got worse I've got a flashback regarding Haynes manual, broom handles and "differential gears"
here is a pic:
So, is that it? If it is, what do I do next? If it is not, what is it then?... As I said, panic mode here
Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
93 GL In progress BP/hydro G
15 Mitsubishi Mirage daily
88 Dakota tow pig
Where is this pic from? Do you have more?Originally posted by Movin View Post93 MX-3 type F
So, where does the axle supposed to be? Inside #5 & #6? Judging by the shape I would say I was touching the back of the teeth on the outer side
rusEfi - DIY ECU
93 EFI: tach cluster, aspire mirrors & spindles. ZX2 master cylinder, BP+G25 swap with a door hinge, rio struts. 205/50r15, 140mph speedometer,rear disk brakes, mini cooper + subaru front brakes rear sway bar
here are pics
passenger side
driver side
Any chance to fix this without taking tranny apart?rusEfi - DIY ECU
actually now that I think about it I might have started the car in gear and without the axles
rusEfi - DIY ECU
Looks like it dropped to me, that's no good
1991 blue L, 5 speed.
1988 red L-plus-all stock.
