(panic mode) axles, transmission and differential gears
    Originally posted by russian View Post
    Does anyone have a sketch of F gearbox inside? Would be helpful to know what I am fishing for
    93 MX-3 type F
      The clips didn't get a little buggered up did they?
        Take the clips off and slide the axles in. If they go in there is no problem with the tranny but a problem with the clip and/or installation. If the axle doesn't go in still, there is a problem with the tranny.
        The Festiva Store
          He already said he tried WITHOUT the clips....
            You are looking for SPLINES! Gears & splines. Stick your face in there. Look in the holes.And you should be able to see clean through the tranny.
            (And should see two sets of splined side gears for both axles. It doesnt matter if its a E,F or G series.They are all going to have similar side gears with thrust washers.
              Lol, misse
              d that with all the confusing posts of people who don't have a clue what's going on. I have never had the gears move on me even with trannies that have had the axles removed and been stored for awhile and moved around alot. I have seen damaged splines on axles though, people getting too aggressive with a hammer and trying to force things.
              The Festiva Store
                stop using hanes manuals..they suck.
                  If the clips buggered up the splines they are easy to file. If you have
                  the F transmission the gears should not slip like they can on the festy
                  transmission. If you have messed up splines the clips are too. May
                  need new ones. The gears are harder spline material and will not
                  be messed up as easy as the shaft can get messed up. Even a dremel
                  tool can fix bad spline spots.
                  • #24
                    Lol, misse
                    ??? I have thrown them from car to car dropped them with no problems .But
                    I have had the gears drop before . Sucks breaking the case to correct the problem and do it again Haha .. but I don't have a clue !
                    New build on the way .
                    • #25
                      I was struggling to lock axles back into my stock manual transmission after an engine swap and at some point after multiple ins/outs/light hammering they have stopped even going inside as deep as they used to go in! It was 1/4" out while I was struggling and now it is 3/4" out! And as soon as I have realized things got worse I've got a flashback regarding Haynes manual, broom handles and "differential gears"
                      here is a pic:
                      So, is that it? If it is, what do I do next? If it is not, what is it then?... As I said, panic mode here
                      So what happend to "stock manual trans", now its an f-series? If your trying to use stock e-series axles in the f-series that's the problem.
                      Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
                      Dennis
                      93 GL In progress BP/hydro G
                      15 Mitsubishi Mirage daily
                      88 Dakota tow pig
                      • #26
                        Originally posted by Movin View Post
                        93 MX-3 type F
                        Where is this pic from? Do you have more?
                        So, where does the axle supposed to be? Inside #5 & #6? Judging by the shape I would say I was touching the back of the teeth on the outer side
                        rusEfi - DIY ECU
                        93 EFI: tach cluster, aspire mirrors & spindles. ZX2 master cylinder, BP+G25 swap with a door hinge, rio struts. 205/50r15, 140mph speedometer,rear disk brakes, mini cooper + subaru front brakes rear sway bar
                        • #27
                          here are pics
                          passenger side
                          driver side
                          Any chance to fix this without taking tranny apart?
                          rusEfi - DIY ECU
                          • #28
                            actually now that I think about it I might have started the car in gear and without the axles
                            rusEfi - DIY ECU
                            • #29
                              Looks like it dropped to me, that's no good ((
                              1991 blue L, 5 speed.
                              1988 red L-plus-all stock.
                              • #30
                                http://www.fordfestiva.com/forums/sh...ad.php?t=39641
