That thing really doesn't look that modified from the inside, i really am impressed with that beast of yours!!!
RWD Probe LS Power!
Well when I get some pics of the total inside you might change your mind, ha ha, there is no back seat, just sheet metal....93 Probe GT-Twincharged-11.992@115mph 10lbs
-11.940@111.66mph 14lbs(Slipping clutch)
123.7mph highest trap
95 Probe GT-RWD-4.8LS-Turbo in process-10.240@135.3mph, Turboed, 3300 race weight
Tossed the LS6 cam in last night, got up to a point where I had fresh oil and full water/coolant, and started her up. Purrs like a kitten! Can't wait to drive it! I think I will work on getting a heat shield made for the intake pipe first, before I throw it completely back together.
John93 Probe GT-Twincharged-11.992@115mph 10lbs
Have you ever, or going to, dyno that thing?
If I get around to it. I don't care about dyno numbers. I log my stuff so I know if I see knock, and I just use my MPH in the quarter to show improvements....
But just for laughs I might dyno it with this cam and open exhaust to see what she does....
JohnLast edited by Damkid; 09-23-2011, 09:31 PM.93 Probe GT-Twincharged-11.992@115mph 10lbs
Well, took the car for a spin last night, felt a tad bit sluggish off the line compared to before, which I expected, but overall it feels pretty good! Hard to tell how much it helped, but I'll find out next sunday when I go to the track.
With less low end torque, it does get me up a little farther on the converter, about 1850-1900rpm, compared to 1600-1700 it was at.
I am predicting around a 12.70-12.80 with this cam, and the exhaust dump I will use at the track, as long as the temp stays cool....
It's on the list, but not a priority. I will probably keep it at 3000 stall, This car is driven everywhere and don't want to go too big....
I race it all the time, the stall will just drop me 6 tenths, ha ha
COngrats! Nice job. You can tell the converter is still a little tight off the line, but if you drive it a lot on the street, it's probably about right. You might try picking up a spare 3rd member for the 9" with a set of 3.89's or 4.10s. If you were local, I'd even give you one to try! It may help with the new cam and swapping the 3rd member is pretty quick & easy. Keep the updates coming!Last edited by blkfordsedan; 09-30-2011, 10:16 PM.Brian
Well if I do that I will put the original 3.23's in the spare one, cause once the turbo goes on this winter, it will want that gear.
I am planning on about 145 mph, ha ha
I'm jealous drool
lol, it's just a probe.....I wish I had more vids of my other probe, it sounded straigh nuts! I might have posted it before, but here is the video of my clutch slipping pass.....
Update: Got the turbo, got the Bosch 044, and now also have a WTA intercooler. Also I chopped up some exhaust sections and my buddy welded them to form the up pipe, which I will be working on more tonight. Once the flange is on I will make a brace plate to help hold the turbo up.
Pics:
As soon as I get the flange tack welded to the piping and get the tube to match the rec port of the flange, I will post a pic or two of the turbo sitting in the engine bay. A real benefit to having the water to air intercooler is I will have less than 40" of intake piping! That should reduce spool time by a few hundred rpm....
Thanks again for looking
Awesome update man, I haven't been following this thread but I definantely am now! You got a build thread for the twin charged car?sounds sick!1992 white L, Bp, American racing 13's, stock trans.
1991 blue L, 5 speed.
1988 red L-plus-all stock.
