Yeah there are a few probe bodies on drag chassis, but this is a regular probe that is a street car, those ones have like 2500hp, ha ha
RWD Probe LS Power!
Well I should update this a little, I made some changes, tuned her a little bit, and last friday in 90 degree weather I went 13.46@103mph, with a 2.0 sixty foot. This is still NA, on pretty much the stock 4.8L.....
John93 Probe GT-Twincharged-11.992@115mph 10lbs
-11.940@111.66mph 14lbs(Slipping clutch)
123.7mph highest trap
95 Probe GT-RWD-4.8LS-Turbo in process-10.240@135.3mph, Turboed, 3300 race weight
Not bad for start! Sounds like some traction issues? Are you running drag radials? You should be able to get 13.10's or better with a good 60' and a 103 trap speed.
Think you can break into the 12's as it sits now?Brian
My starting issues aren't traction, I have ET streets on it. The problem I am having is I cant get up on the stall(it's auto), I get to 1600rpm and it starts pushing the car through the brakes. Once I get that fixed I am hoping for 1.8 60' and with colder weather I should see high 12's, or it's just a cam away, lol93 Probe GT-Twincharged-11.992@115mph 10lbs
ha ha, thanks!Originally posted by mr2gq View PostI hate people like you....lol jk thats freaking bad ass. Wish I had the knowledge to pull something like that off93 Probe GT-Twincharged-11.992@115mph 10lbs
did you get any vids of this bad boy at the track?
What stall on the converter? I vote get a 125 shot and spray that bad boy..........boost would be good too, but spray would be quick, simple, cheap and very stealth!Originally posted by dueces View PostMy starting issues aren't traction, I have ET streets on it. The problem I am having is I cant get up on the stall(it's auto), I get to 1600rpm and it starts pushing the car through the brakes. Once I get that fixed I am hoping for 1.8 60' and with colder weather I should see high 12's, or it's just a cam away, lolLast edited by blkfordsedan; 09-09-2011, 10:23 PM.Brian
^ and what's stealth about a V8 probe?Trees aren't kind to me...
ha ha, very true! I have debated throwing on some nitrous, but I really don't have the cash for it. I don't have any videos as I usually go to the track myself. The stall is a 2200, but I am only seeing 1600 or 1700, which it might just be too tight of a converter....
On a better note, the car went just a little faster tonight, 13.27@104.1mph. That was with no changes, just a little better temp outside.....
Considering the light vehicle weight and small displacement you probably do need to go a little looser. As it is now, I bet its probably about perfect for a street/DD/cruiser. There's certainly more in it, but IMO, 13.27@104 is pretty good considering your total $ investment. I would be pleased anyway. At least post up some new pics!!Brian
Well I just found out I have been lying about the weight, I weighed it on a scale and it's 3240with me in it! I only weigh around 175 so it really weighs 3062lbs, so it's not as light as I thought it would be, the guy I bought it from could not have been even close to 2650lbs, but that really doesn't matter, it is what it is....93 Probe GT-Twincharged-11.992@115mph 10lbs
well here are some pics, this first one is my three runs last night.
Well, I am stuck on 12 hour days right now, so the updates will be few and far between for now. I started taking the front of the car off so I can put in my LS6 cam. I double checked both the part number, and the size of the lobes, and it is a true LS6 cam 02+, which has the .551/.547 lift!
This is how I left it, only worked on it for an hour, just have too much to do, and after working all day, you get tired quick.....
Thanks for looking,
