My KLZE Festiva Build Thread
  • ^^I'm not sure about that seam on the firewall, i don't think the KL-ZE has that vacuum piece on the intake to get in the way (I hope) so until i get the KL-ZE home and in my festiva, i'm not going to worry about that part yet
    • God this is gonna be boss when it's done! perhaps, the ultimate sleeper??
      Ok, well now you've gotten ------g silly. ~ MONSOON
      • Originally posted by Damkid View Post
        ...although i have been considering manufacturing a mount kit for the g25 tranny
        Don't consider it, do it!
        • Originally Posted by Damkid
          I'll 2nd that!
          '93 Festiva L 5spd.:
          Aspire swap: brakes, swaybar, master cyl.
          Aloha! ....renny
            "That vacuum piece" is for your VRIS. The KLZE has VRIS it just opens at different RPMs and that is what provides you the extra power in the different rpm range. It also what gives people headaches when they swap the KLZE and don't have the right ECU. I think you are right about it being in a different spot on the KLZE intake, but there are two of them on each intake, so one might move but the other might end up in the way. In my mx-3 with the KLDE they are right up near the firewall, It was a bear hooking up the connector because I had to do it from below the car, but had to reach to almost the top of the engine with virtually no space between the engine and the firewall.
            The Festiva Store
            • I wouldn't worry too much about the vris stuff if you plan to boost. I would remove it and tie the butterflies open. My dd probe and my turbo probe are this way. Plus in your situation it will free up room and you won't really notice a difference in power especially in a festiva
              • Cool. I was looking at the clearance pics. Do you think you will need a FMS hood to actually clear the engine since it has the raised center part? That would be sweet. Funtional hood bulge, not just for show.
                '89L 110k mi. BP/G swapped
                '90LX 68k mi. wrecked 12/14 RIP
                '90 F250 4X4 108K mi.
                '13 Kia Rio 5 LX 70k mi.
                '18 Kia Soul 40k mi. Daily
                '64 Studebaker Gran Turismo Hawk
                '66 International Harvester pickup
                • He allready have a FMS fiberglass hood and he just bought a carbon fiber one from festivaWES
                  BPT, G5M-R, BP26 Exintake swap + Fidanza cam gear, NSRT4 FMIC + 2.5" piping, HKS SSQV BOV, Exedy clutch, 3" downpipe + 2" all the way back, Aspire brake swap, KYB GR-2 & FMS coil spring , FMS EURO body kit + Carbon fiber hood, Falcon RTX 15X6½ + Toyo proxes T1R 195/45R15
                  • Originally posted by nonamekid View Post
                    This is good info for me to know before i buy an ECU, which ECU woud be best for the stock KL-ZE set-up?
                    This is a good idea and i may do this even before i boost it just to free up space at the firewall :lol:
                    It actually looks like it would clear a stock hood which is cool!!
                    I made up two brackets today to re-attach the rad support, if i get to it today i post pics
                    • You should totally get a Lexan hood made... This engine needs to be seen by everyone!
                        It depends on which intake manifold you use. The curved neck manifolds have different VRIS points than the straight neck manifolds. The rest of the information I have stolen from mx-3.com
                        Originally posted by mx-3.com
                        kl31/36 - straightneck VRIS
                        k8 - k8 intake VRIS
                        k8 with millenia probinator chip - curved/millenia intake VRIS
                        kl01 - klde intake manifold VRIS
                        Curved neck Vris is;
                        ON OFF
                        Vris 1 3750 6200
                        Vris 2 4250 6200
                        Straight Neck Vris is;
                        ON OFF
                        Vris 1 3800 6600
                        Vris 2 4800 6600
                        To get the proper vris points, you would need to do 4 dyno runs.
                        One with both VRIS closed
                        One with both VRIS open
                        One with VRIS 1 open
                        One with VRIS 2 open.
                        You need to manually keep them closed/open.. and also disconnect and plug the vac lines running to the actuators.
                        Overlay the torque curves so that you can see where they intersect, and those will be the optimal vris points.
                        It would be beneficial to do the dyno runs if you modify the engine and would like as much torque as possible out of the motor throughout the whole rpm range. Open VRIS is good if you plan to stay in the High rpm range all the time. If you plan on using the rest of the rpm range I would suggest keeping VRIS and getting the opening and closing points set properly.
                        The Festiva Store
                        • ^^Thanks for the info! i'll have to do some playing around with it, i'll try to get them working properly at first then worst case senario i'll tie them open :lol:
                          • IF this isn't already, it should be stickied! Great thread, and a festiva pioneer in my book. Can we buy advance tickets for rides?
                            • ^^Thank you Logan! I'm sure at the next meet i make it too, there will be rides :lol:
                              • Hey kid, I havent been around a lot and just noticed this thread. Man if you pull this one off it would be awesome ~!~ Cant wait to see it happen.
