My B3-T setup
  • #61
    Like fastiva has shown a couple times haha
    1991 blue L, 5 speed.
    1988 red L-plus-all stock.
    • #62
      ^yup exactly.
      • #63
        Arty and I had to replace mine because of what we suspected to be this issue. So should I just plan on a trans swap? What trans should I upgrade to when I boost the b6?
        • #64
          ^ bobby, yours was an input bearing failure.
          • #65
            Oh yea thats rite haha. I need to come see ya soon bro! No work just fun
            So what trans for us single cam guys that want to boost without going through clutches?
            • #66
              F-series would be plenty in my oppinion.
              89L build thread http://www.fordfestiva.com/forums/sh...ad.php?t=36422
              My site: 20tessa.sytes.net
              • #67
                you can use the E series as long as you roll on the throttle. the tires will brake loose well before the trans does in that case.
                • #68
                  Do you guys think An f should hold a boosted bp with a good clutch?
                  • #69
                    depends on how much boost.
                    • #70
                      Let's say 20 psi.(of course there's alot of variables) I'm talking about a disk style clutch, I figure a puck would just make things go bang!
                      • #71
                        clutch material doesn't matter so much as it's engaugement (i.e. use a sprung hubed disk).
                        • #72
                          I used a 6 puck ceramic on a N/A bp and I couldnt get it to slip at all. Not sure if it would be ideal on 20psi.
                          • #73
                            why wouldn't it? as long as it doesnt slip and doesn't slam the input shaft, you're good to go.
                            • #74
                              So you don't think A ceramic puck would be to harsh on tranny's?
                              • #75
                                so as long as i dont go w.o.t. i should be fine? i can just see me going through a trany quick you know how i drive arty . oh well ill do it any way and when i do go through the trany ill just upgrade then. is there an available preformance clutch that is reasonably priced for the e-series trans that i can buy?
