Very nice guys, I would really like to do this so I can lower this baby. Gotta do some work on my Capri first.
Thanks again.
Ultimate Street suspension guide
This is a sticky topic.
Mine have a build date stamped on them of January of 2017. Looks like you got the last of the old batch maybe!?
must be quite a recent change, i grabbed a set around 2 weeks ago and they look like this.
hopefully i grabbed the right set lol. This was the link. http://www.ebay.com/itm/VOLKSWAGEN-V...53.m2749.l2649
20170625_084620.jpgOriginally posted by greywolf200 View PostPics please.
I havr not swapped my springs yet but here is the new coilovers. Also u can sre how i put tape on the body. This allows me to cut only the areas i want to.u can use paint or whatrver u want but for me the tape works best
The coilovers from hot tunning on ebay are now a bit different. I like them much better now. The lower body is much simpler and heavier duty. The mounting brackets that the bolts go through is now flat and much stronger looking.
If you look back at my original holes i messed them up big time. I was a bit on the drunk side. I have since found out its best to slot the lower hole up a bit (1/4"ish) and the upper hole inward a bit (1/8"ish). This will do 2 things. #1 it will lower the strut on the knuckle by the (1/4"ish) and #2 it will allow you to add in the neg camber.
One issue with the new design is that the upper corner of the mounting tab is quite square. It makes the corner stick out more the i would like. I am running 13" rims and i will have to use a small spacer to clear the strut mounting tab.
I used the Afco sleeves on my first set. They offer a 7" long sleeve too iirc. That's a nice option to have.
If any Aussies are looking at parts for this upgrade, there's cheap AFCO coilover sleeve kits (to suit rear - MK1 golf KYB struts) available at the moment,
$42 per kit (2 needed) here
Probably the cheapest you will find in Oz at the moment. Only 2 left so be quick!Last edited by reddragon; 05-17-2017, 12:57 AM.
They where used on the spring perches that come with the shocks not the coil over sleeves.
Sent from my SAMSUNG-SM-G900A using Tapatalk
Seems like tominmo used Bilstein one time. I believe there's a thread on here.
Someone here used the Bilsteins and made a concise report. But I can't remember who, nor find the thread.
Sorry for resurrecting this thread but I have a question.
In the original how-to you use KYB rear shocks, is their any problem with using Billstein rears? They are only about $5 more and I feel a little bit better quality.
dragonhealer, i emailed you! thank you! yeah that part firebush, either way this one that I made work is doing the trick for me right now!
