Ultimate Street suspension guide
This is a sticky topic.
  • Dragonhealer
    replied
    Originally posted by Grey Vw View Post
    I chose 150lb with the stock engine and tranny in preparation for the the eventual swap. I thought preload was just set by having the suspension fully unloaded and then just tightening it to keep the spring set compressed. If anyone better information I would appreciate it
    Have you tried running the shock tube all the way through the lower mount and putting the lock nut on the bottom?
  • FestYboy
    replied
    Originally posted by Advancedynamix View Post
    The Capri knuckles do this without the blocks.
    But you run aspire knuckles...
  • Grey Vw
    replied
    Originally posted by william View Post
    What sprig rates are you running?
    I have 150 # 12 inch and with my springs preloaded to 10 inch my 165/55/14's only have an inch gap .
    I am running a b6d with g series moved forward but
    120 springs with stock engine and trans should let you go really low.
  • Advancedynamix
    replied
    Any further thoughts or progress on the ball joint lowering blocks?
  • william
    replied
    I am very appreciative and thankful for this thread, but I am a bit upset. I assumed this was parts list was copy and paste from what Charlie does.
    This front spring is 12" while in Charlie's thread it is 10". I now cannot achieve the ride height I wanted. With the collar all the way down and the shock length adjustment I cannot go lower than 3" fender to tire gap. Partially my fault for not doing thorough research. Please note this in your original post.
  • FestYboy
    replied
  • Advancedynamix
    replied
    I'm now using 12" 120lb springs on the front of my setup as well. I think there is a write up that fell in between my original write up and Mike's write up that details the new setup. Sorry for the confusion. I've gotta take the time to clean all this info up into 1 basic article. I haven't done that because things are still being developed and new ideas are being implemented.
  • Grey Vw
    replied
  • Advancedynamix
    replied
    ^ what Arty said. They actually are desiged to lock when the load of the car is on them. That is why you don't need a retaining (Lock nut) with that style of sleeve.
  • FestYboy
    replied
    Preload and hight adjustments should always be made with the suspension unloaded. Otherwise you run the chance of galling the acme threads. Plus, it's much more difficult when the springs are loaded.
  • wwwdotgov
    replied
    Is there a coilovers "spanner wrench" that's needed for use with the Southwest Speed coilovers sleeve kit to adjust ride height?
    Or are all height adjustments made with the rear end dropped/sagging and struts unloaded?
  • mikemounlio
    replied
    I am buying a full second set of this suspension! It will go on my new bpt festiva/b6t. One set on each car. Right now my 1st set is on overkill so this set is lined up for lucifer.
  • Festiver
    replied
    Like Brad said, the VW rear shocks are shorter and don't require that mod.
    On the KYB Aspire shocks, yes I shorten them 3“. I cut the shafts up by the locator bushing for the bump stop. I cut 3 inches out of the shaft, then drill and tap both parts ¹/⁴-28 and use a stud to hold them together and I tig weld the shaft back together.
    These are pictures of a set of Tein coilovers that I shortened, so the shaft looks different than the KYB Aspire shocks, but the procedure is the same.
    The MK2 rear coilovers are not worth using unless you want to lift your Festiva. The shock bodies themselves are way too long.
    Ohh ok cool cool nah I thought you shortened the mk2 fronts and the mk1 rears even more glad you didn't because I'd be worried of messing it up
    Sent from my XT1585 using Tapatalk
  • Advancedynamix
    replied
  • Festiver
    replied
    Originally posted by bhazard View Post
    No that was the festiva struts he originally used. That's what's been bothering me about this thread.
    Ohhh alright cool that's what I was worried about and what do you mean it's a little bit of a mess but still good info
