Re did one of the brackets to make it a little beefier. I use the stock battery tray mounting points so I didn't have to drill new holes. Might still need some tweaking of the angle but otherwise I'm pretty happy with how it turned out.
I did it this way rather than moving the battery to be back for two main reasons. I wanted to keep weight up front and then I wanted the battery wiring in the same basic spot as stock.
Next up... VAF bracket!
Condenser to radiator clearance.
View from the other side.
Minimal clearnce between the compressor housing on the turbo and the radiator.
A/C condenser in place.
