Re did one of the brackets to make it a little beefier. I use the stock battery tray mounting points so I didn't have to drill new holes. Might still need some tweaking of the angle but otherwise I'm pretty happy with how it turned out.
I did it this way rather than moving the battery to be back for two main reasons. I wanted to keep weight up front and then I wanted the battery wiring in the same basic spot as stock.
Next up... VAF bracket!
